HAB Research Assistant
(Requisition 77903022-51315799-20150128133001)
The Fish and Wildlife Research Institute, the research arm of the Florida Fish and Wildlife Conservation Commission, invites applications for an OPS Research Assistant position in the Harmful Algal Blooms (HAB) group. The position is located in St. Petersburg, FL and is a full-time, hourly position starting at $16-$18/hr, depending on experience. This is a time-limited position; continued employment is anticipated but contingent upon annual state appropriations.
The successful applicant will conduct analyses for the detection of marine algal toxins in seafood, seawater, and other environmental matrices using ELISA, HPLC, and LC-MS techniques; evaluate new methods and technologies for regulatory shellfish testing; and participate in collaborative HAB research. Primary duties will focus on conducting analyses for Paralytic Shellfish Toxins using HPLC-FL and providing analytical support for the state’s shellfish biotoxin program. Professional experience in a chemical or biological laboratory setting is required. Experience with HPLC or LC-MS techniques is strongly preferred.
Please see the full announcement here: https://jobs.myflorida.com/viewjob.html?optlink-view=view-777108&ERFormID=newjoblist&ERFormCode=any. To apply: 1) submit a State of Florida Employment Application Form electronically at http://peoplefirst.myflorida.comand 2) email a cover letter, CV, and the names of three references together in a single PDF document to FWCHAB@gmail.com. Only applicants completing both steps will be considered. Applications will be accepted through 2/28/15.
Inquiries about this position may be sent to FWCHAB@gmail.com.
