Chemstation A.07.01 saving two files
Hello all. I'm hoping someone has some insight into this issue. I have a 6890 and I'm running CS A.07.01. I've used newer versions of this software so I'm not sure where I'm going wrong with this one.
When I run my method CS is saving two files. One has my chromatogram in it, the other has nothing (when I try to open it it says no data). In the part of the method where it lets you save two signals I have the one on the right (Signal 2) set to not save data (box is unchecked). A.10.02 is different but similar and I don't have this problem.
Does anyone know where else I need to look to tell it to only save the one file with data in it? Thanks!
Actually, it saves a directory for each sample. Individual files for each signal, report(s), sample info and so.
Ok, so how do I get it to only save one directory per run? It's not a huge deal, just kind of annoying when I go to open a file and there is no data in it, plus it's creating double the directories but half don't have any data.
Like I said, where I think this is controlled in the method I have the left side back detector selected and save data box is checked. On the right the save data box is not checked. What am I missing?
You may have set up the system to save everything in two different places. This is not typical, but for example, if you set up the default config location (where you setup your default directory locations for: Data, Methods and Sequences) for one drive path and your individual method and files to over-ride it and save everything to another location, then you might end up with two copies.
BTW: I do not understand your comments about right side and left side data. ChemStation works with METHODS, that you create (please do not overwrite them!) for a specific task or application. Within the method is a Run Time Checklist, you select if data analysis is part of the method, and if so, if you also want to automate reports too. Within the method, you will have one or more detector set-up screens. Within those screens you can select signals, choose their properties and optionally "Save" them as part of the method. In the Report section, you can select output types. This includes files and/or reports. ALL of these things are part of one method and when you save the method, you save all the choices you made (you can of course go back and edit them later). So there are lots of places where you could request that the system save specific files as part of the method and store them (somewhere). Use the "Edit entire Method" feature to step you through all of the logical screens so you can review them. If you have not done so already, I would strongly recommend taking a training class in the use of ChemStation too. It is super easy to use, very logically laid out and organized. However, if you have used some other system before, it may appear odd at first (change always make people dislike the "new" system at first).
Most users ever online was 234 on Tue Feb 06, 2018 7:33 am
