Missing Perspectives in OpenChrom
I'm working with Openchrom 1.3 for win_64 which I like very much but still, some issues need fixing:
[list=][/list]The perspective list is limited and needs to add/install others like: "Peak identification", "Denoising", "Manual Peak Detector", "CSD", "Chromatogram Peaks", "The OpenTyper" perspectives
[list=][/list]The installed perspectives do not change automatically
[list=][/list]How to get the peaks in the chromatogram labeled with the components name? How to edit the label text (change direction horizontal or vertical)?
[list=][/list]The "AMDIS Peak Detector" is installed properly in the preferences, but is not showing under the 'Chromatogram/peak detector'
[list=][/list]The same above for the "NIST identifier"
Thank you in advance,
M. Osman
Version 1.3 is so largely outdated that you should consider https://www.openchrom.net/download a newer version. Major change to the interface is that you there is one main (chromatography) perspective called data analysis. You can switch additional windows on/off in the toolbar. The chemometric operations are done via the right-click menu on the chromatogram.
Subscribe to our eNewsletter with daily, weekly or monthly updates: Food, Environmental, (Bio)Pharmaceutical, Bioclinical, Liquid Chromatography, Gas Chromatography and Mass Spectrometry.
