doubt regarding Carbendezim and benomyl
I am testing pestcides in Rice according to COMMISSION REGULATION (EU) No 893/2010.In this there is a combined MRL for Carbedezim and benomyl since benomyl has low stability and is hydrolysed to carbendezim easily.I have doubt that is benomyl & Carbendezim included in the mix standard or i run carbendezim only.
You run carbendazim only. There are special prep methods that you can use to keep from hydrolyzing the benomyl, but under the standard EU/FDA prep procedures you will only get the peak for MBC.
Mark Krause
Laboratory Director
Krause Analytical
Austin, TX USA
Thanks for your valuble infomation
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
