Alltech 500 ELSD, HP 35900E, 1100 HPLC - HELP!!
Hoping for some help here... I am attempting to setup an Alltech 500 ELSD with an 1100 HPLC using an HP 35900E analogue box and Chemstation A.10.02.
The 1100 communicates to the computer via LAN. The HP 35900E box we have is GPIB. So, first question, does the GPIB on the 35900E need to be connected to the computer, or can it connect to one of the 1100 modules? If so, which one? There is an autosampler, quaternary pump, column oven & diode array detector in the current 1100 setup. Currently, the DAD connects to the computer with the LAN via the JetDirect card. I've read conflicting statements - can I get around having to buy a GPIB card for the computer by removing the JetDirect card from the DAD and installing it into the quaternary pump? I haven't tried this yet. I have tried connecting the 35900E via GPIB to both the pump and autosampler so far, to no avail. After configuring the 35900E module in the configuration editor, I receive the following error message when initially connecting to Chemstation: SICL32.dll was not found. Subsequently, the software tells me that it doesn't "see" the 35900E box.
Thanks for any advice on whether I need to purchase a GPIB card for the computer, or if I can somehow connect the 35900E to my LAN based 1100 system.
Regarding my Alltech 500 ELSD setup, I am also wondering where the remote start cable from the 35900E box should connect on my 1100? Guessing either the pump or autosampler would work? Finally, in connecting my signal cable from the ELSD to my 35900E box, does anyone have any suggestions? I have one end of the cable connected to input A on the 35900E, but wasn't sure exactly where the two wires need to feed into the back of the ELSD.
Thanks for any suggestions! I'll be glad when this setup is finished so I can finally start generating some data.
We had similar situation: wanted to move an 35900E from an 1100 system that had been GPIB to a different 1100 stack that communicated with LAN. Our ELSD was Alltech 2000, but that's irrelevant here.
Anyway, we ended up just buying a new 35900E box that was LAN, as the LAN upgrade we had purchased for it from Agilent wasn't the entire issue. We thought it would be as simple as replacing that GPIB part of the 35900E with the LAN part, but that apparently wasn't the whole story. The technical reason is over my head.
So I'd call Agilent or 3rd party vendor, get their input, and make your decision contingent upon returning whatever you buy if the system doesn't work. Get that in writing if possible.
I have the same problem, I have Varian Prostar with 2 210 pumps + autosampler 410, Column valve 500 and an ELSD Alltech 500. I have Workstation Star installed software. I don't know how I can add ELSD500 on this software or how I can connect it to the computer. Should I buy a software for this detector? Anybody can help
thank you
Users browsing this forum: Google [Bot] and 9 guests
