calculating first and second moments
I'm trying to determine diffusion coefficient from the flow profile of an analyte injected into a stream of toluene by it's time vs UV
data. I have time (t) in seconds and UV absorbance (h) in mAU. I calculated M0 as the sum of the h values.
Is M1 just 1/M0 * sum of the h*t?
What is M2?
Marc
I've always worked with the definitions that:
M0 = area (so, h*t in your case; this is usually normalized to be unity).
M1 = mean
M2 = variance
M3 = skewness
If you can wade through the math (my eyes glaze over!), more detailed discussion is here:
http://en.wikipedia.org/wiki/Moment_%28 ... he_moments
Users browsing this forum: Semrush [Bot] and 10 guests
