S/N 5972
HI I want to calculate S/N for a 5972 MSD trough MSD CHemsation. G1701 BA REv 2.0.
Somebody comment about this.
Another issue, Where found the protocols IQ/OQ for this detector?
For your answer thanks
Beeing in ChemStation press F1. You'll find desired information I hope.
I have seen in the help that there is a signal to noise function in data analysis, but it is not appearing on my menus, so I imagine it depends on what type of system you set up when you created your instrument profile. In Enviroquant which is what we use the option is not there, so maybe in the Enhanced mode it will be there.
Hi everybody thanks for your answer, I looking for this option in the software and don´t found. Now I will review the macros, I hope to found the answer there.
Thanks for your help.
In G1701DA ver. D.01.02.16 in Enhancement Data Analysis you simply choose "Tools" from menu and "Signal to Noise check ..."
I have no access to previous versions of ChemStation so can't help. Maybe S/N check was not implemented in previous versions.
