Very basic question regarding fatty acid analysis
Hello Fellow members of this forum,
I was wondering if anyone could find time to answer my question.
I need to present my fatty acid data in mole% but I do not know how to change the peak area into mole%.
Following is the link for data I have ( I did not know how to attach it therefore I uploaded it)
https://www.box.com/s/x3n2phbzxj7ntun62jwt
Can any kind soul find time to let me know?
Thanks a bunch :)
Your chromatogram is not one which is cleanly showing only FAME peaks. I suspect you have decomposition of unsaturated FAME as well as other possibilities, under and bordering the FAME peaks. There may also be hydroxy FAME peaks.
FAMEs have a fairly consistent weight response on a FID. 1mg/mL solution of each FAME would give peak areas that are FAIRLY consistent in area. Of course, equal weights do NOT imply equal moles.
Without a standard chromatogram of known concentrations to refer to, I do not know how you can accurately determine mole %, that is assuming you are eluting and are separating all the FAMEs present in your sample.
best wishes,
In total there are 36 users online :: 1 registered, 0 hidden and 35 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 35 guests
