White Fuzz On The Fittings
Dear Members,
What is the source of white fuzz on the fitting? Is it due to capillary leakage of the fittings?
Siswanto Tanuatmojo
Possibly. Could also be due to a little bit of residual buffer left behind when you assembled the fitting.
Dear Members,
Siswanto Tanuatmojo
is it precipitation of buffer salt or an indication of more concentration of buffer?
regards
amaryl
Will it be a problem? Any suggestion for corrective action if it is caused by capillary leakage that may be cannot be seen?
As long as you don't see any visible moisture/fluid, I wouldn't worry about it. Any leakage is probably measured in nL/day.
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 12 guests
