Column and transfert line, Varian saturn 2000
Hi, i have a saturn 2000 but I don't know how much column have to be inserted into the mass spectrometer , does somebody know how many mm of column have I to insert into it?
Thank you
Enrico
1 mm of the column should project from the transferline.
Thank you very much for the answer!
Enrico
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 1 guest
