cleaning
when you try to clean up the inlet or outlet valves, the needle seat, parts of the pump etc and you do sonication, what is the better to use? H2O mQ, MeOH, Isopropanol, H2O with a little acid(glacial acetic)?
Is there any harm that can be made?
As a general rule, something that's a good solvent for whatever kind of junk is likely to have accumulated. Water with a bit of methanol would be a good choice for salt crystals, isopropanol might be a better choice for residual surfactant (e.g., ion-pair reagents).
Be careful. Sonication may damage an intact check valve.
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
Users browsing this forum: Bing [Bot], Semrush [Bot] and 8 guests
