Assay of Quaternary Amine
All-
I spend most of my time in the GC realm so I'd appreciate any advice you could give about my HPLC troubles:
Column = J.T. Baker, Weak Cation Exchange (WP CBx), 5 micron, 4.6x250mm
Mobile Phase = 55:20:25 :: Ammonium Chloride, pH 7.7:MeOH:ACN
Flow = 1 mL/min
Sample concentration = 0.2 mg/mL
Inj vol = 20 ul
Analyte = Quaternary amine (curare derived compound)
Problem = severe peak tailing (>2.5) of compound
What type of adjustments can I make to clean this up? Are there any other similar columns (manufacturers, etc.) out there or is this a very specialized phase?
Thanks in advance for any wisdom.
-Jeff
GoldLeader,
First off, I'd suggest lowering the pH. There's no need to use such a high pH with a weak cation exchange material. Lowering the pH will also help minimize any silanol interactions which could be also responsible for the tailing problem.
Users browsing this forum: Google [Bot], Semrush [Bot] and 7 guests
