AB/Sciex API 3000. What kind of noise?
Hi all,
I am looking for some feedback. I was running a Q1 scan the other day and noticed my baseline noise was between 5x10E4 and 1x10E5. This was 10 scans MCA mode, so if I did not run MCA mode the noise would be 1/10th or about 5x10E3 to 1x10E4 let's say.
Oh, and I was in negative ion mode, -4500 volts.
I thought this was a bit high. I have a much older instrument that gives me almost 1/10th this noise. Would this be considered normal on an API 3000?
Mobile phase was 65/35 MeOH/5mM AmAc aq. and I had a split so I was probably spraying in about 40 -50 uL/min, ionspray.
Q1 scan 50 to 500 AMU.
Alp
Any particular pattern to the noise? Any masses that were dominant?
Time flies like an arrow. Fruit flies like a banana.
A few large peaks, but I am more interested in the baseline noise level. When zoomed in enough it looks like a peak every 2 AMU or so and when zoomed out resembles grass. You all know what I mean.
iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii noise .
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 1 guest
