Locking method templates in chemstation
Hi there,
I am using Chemstation as HPLC data aquisition software (not chemstation plus) and I was wondering whether it is possible to lock files to prevent alterations in for instance method templates? Or must this be done in the windows right settings?
Thanks in advance,
Erik
What revision ChemStation are you using. (Help > About) will give the revision with the build number in [square brackets].
I'm using Rev. B.04.02 [96]
About all you can do in that revision is to set Operator or Manager level. View menu > Change Access Level. You can set a password to get to Manager level.
Users browsing this forum: Semrush [Bot] and 10 guests
