regarding analyte carry over
I am using phenomenex kinetex c18 column for ochratoxin A analysis. Mobile phase(Acetonitrile/2%acetic acid=1:1);Flow rate-1ml/min;
when I used to analyse it I am facing carry over problem. I am not sure what is causing this problem? please help me out from this issue.
Please check your autosampler or injection valve first, than check the Connections from the injection System to the column. It can be caused by extra column effects.
Users browsing this forum: Google [Bot] and 17 guests
