Agilent 7890A GC Pressure and flow problem
Page 2 of 2
LOL! I've been told many times to stop using snoop. But it works so well... And his leak seeker did not find those 2 leaks
Snoop doesn't work at all on hot surfaces like inlet and detector connections.LOL! I've been told many times to stop using snoop. But it works so well... And his leak seeker did not find those 2 leaks
If you must use a liquid try a 1:1 mix of water and isopropanol. It's viscous enough to work but should not contaminate anyting.
MUCH better than Snoop but it still doesn't work on hot connections.If you must use a liquid try a 1:1 mix of water and isopropanol. It's viscous enough to work but should not contaminate anyting.
Ha! I though I would get some sort of notifications if there where posts on my threads!!!
You are right Snoop doesn't work on hot stuff... but my bosses will not let me buy a 1500$ leak seeker... So I make due with what I have. I may try the isopropanol mixture.
One temperature programmed run with a leak in the system can destroy a polar column - a question for your boss; how many columns do I have to destroy before the leak seeker would have been a better investment than a bottle of Snoop ?
Good point...
I'll ask him after I get my christmas bonus
Happy holidays to all!
Page 2 of 2
