GC column for EP compendial method
Dear all,
in an European Pharmacopoeia compendial method for the analysis of residual MeOH, Ethanol and aceton in API is prescribed to use the following GC comun:
Material: fused silica
size:l=10m, diameter 0.32 mm
stationary phase: stzrene-divinzlbenyene
Could you help me to find the commercial column equivalent to this descprition?
Is it a PLOT column?
Thanks a lot
GT
Closest thing I could find quickly (it's a 100% DVB PLOT phase):
http://www.restek.com/catalog/view/8435
Here's an application note where it is used:
http://www.restek.com/chromatogram/view ... %7C67-56-1
Good luck.
Hi rb6banjo,
thanks a lot for your help.
GT
