Fixing old spectrophotometers
Off-topic conversations and chit-chat.
9 posts Page 1 of 1
You might have noticed a lot of old spectrophotometers and other instruments on Ebay. I collected a lot of information and put it on this website: http://antiquesci.50webs.com/index.htm
I got a Perkin Elmer 337 and 727 (IR) working, but they might need new detectors for better resolution. I got a Coleman 124 (UV/VIS) working, too. I recently picked up a Beckman model 25 UV/VIS spectrophotometer, but the deuterium lamp doesn't light. Does anyone here have a schematic and/or manual?
Also see
http://www.4shared.com/dir/2077108/ab6c ... aring.html
for articles and books on spectroscopy, polarimetry, etc.
I might have one snce I am from Beckman. We recently closed down our main headquarters in Fullerton CA and got a lot of old stuff out of it. One of the docs I scanned might be this manual. Email me at stev434@hotmail.com with DU 25 spec as the subject line and will get back with you.
I'm still looking for a Beckman model 25 service manual.
I actively use a Fisher Spectronic 20D with rotating knobs for blanking, and changing wavelength.
I would like to discuss and learn from you all how to develop method in a faster way.
How are you guys find the direction of solution? By experience? By reading?
Decrease your exam stress by using our latest 501-01 exam and best quality Test-king.com
Perkin Elmer 337 update.
Better capacitors and twin T filter improves performance.
http://antiquesci.50webs.com/PE337/PE337-6.htm
Thanks for the update. I have two Perkin Elmer 337's. Here's a before picture showing the Bumblebee and Black Beauty capacitors you replaced.
Oohhh vacuum tubes. They are like little spaceships :D . My old man is still looking for the ones I pulled out of his TV.
9 posts Page 1 of 1
