Injecting vial from the injection turret?
How do i get my GC 7890B to inject from the injection turret?.
maybe you could start explaining better your problem
Vial number 101 in the sequence file. I assume you do not have a tray? On the older towers you had to have a particular turret but I do not think that is the case in the new towers.
Best regards,
AICMM
Best regards,
AICMM
Best regards,
AICMM
We have 7890B also, pretty new, but I've only used the tray/tower combination to inject, so I can't help directly on this. Likely the operating manual is on one of the discs, they don't print these apparently any more.
Anyway, AICMM is correct about the 7673 towers; one needed to remove the tray circuit board from the control box and use little plastic spacers in the tower turret, and #1 spot was 101, etc. I remember that changeover information was sort of hidden.
Maybe the new electronics are smart enough to "know" that 101 means to inject from the tower directly. I assume that you do not have a tray, why you want to do this. Did you call Agilent 800-227-9770 and speak to a telephone technical engineer? One can usually talk to a live person in under 10 minutes, and they will either know or get back to you exactly what to do.
In total there are 20 users online :: 0 registered, 0 hidden and 20 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 20 guests
