floating electric signal
I work on a 450 Varian which has constantly had a floating electronic signal since I started 2 years ago. We are often unable to get a blank could it be the floating signal and/or has anyone else dealt with this issue? The 450 runs dual collumns of Chromosorb PAW60-80, 30 feet X 1/8 inch SS inlet Steel. Loop size is .5cc.
Thank you for your assistance,
J. Gort
May it be an unshielded/non properly grounded appliance on the same power line?
Thank you for the information. I will check into that.
fid? specifying the detector type would be helpful
