Help. Agilent 7890A inlet help.
On my Agilent 7890A the nut on the inlet got cross threaded and required a lot of persuading to come off again. During the removal process one of the two gas lines into the inlet got severed. The best I can find is this:
http://www.chem.agilent.com/Library/sel ... 5451EN.pdf
Part G3430-40035
The turn top. Does this part include the gas tubing or is it just the inlet valve, if you see what I mean? It isn't very clear and I cant get a resonse from agilent.
Any help much appreciated.
Part G3430-40035
Probably this picture will be more helpful:
http://tinyurl.com/turntop
Yes the top weldment includes the tubing.
