No the steam clean didnt make any difference...
I ran only two air and a clean water sample.
No standard
In every sample there was a 0,08pA Ethanol Peak.
Greetings
If you are still getting the same sized peak after a steam clean it points to persistent system contamination rather than just carryover from recent samples, and it looks likely that it is somewhere not affected by the steam clean, so the inlet is looking more and more suspect.No the steam clean didnt make any difference...
No standard
Greetings
