SIM versus pseudoSRM
Hi
I wonder what is the advantage of using a pseudoSRM (parent to parent transition) compared to a SIM. I was told that it is better. Is that so?
It depends a little bit on the reason for the PseudoSRM or SIMSIM or what other names they have for it. If you do it because the precursor ion is very stable and does not produce any fragment ions it can be better than SIM. What you can do is select the precursor ion in Q1. pressurize the collision cell and give it a collision energy so much that you just don't see any loss of your precursor ion in a Q3 Sim of that same ion. This might lead to a noise reduction because all the chemical noise is fragmented and you don't see it in the resulting chromatogram. Increasing your signal to noise.
We are looking to hire a person to do LCMS in an analytical lab in Davis CA.
Pass your 300-101 braindumps on first attempt using Olivet Nazarene University and other resources.
In total there are 65 users online :: 0 registered, 0 hidden and 65 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 65 guests
