agilent 1200 hplc pump drive problem
We have a problem pump drive motor assembly. I am qualification analyst how can i fix the problem o relace a new one? Thaks.
Hello
If you're sure that pump drive is defective you need to replace it.
What kind of problem you have with it?
Regards
Tomasz Kubowicz
Regards
Tomasz Kubowicz
Pump one time starts and one minutes later stop. And then starts. i teplaced all the pump components. i use wd40 pump head. can i open the drive ass. For fixing. I read reference manual but only replace it.
Does it just stop, or does it show an error? (LED is red). If the LED is red, you might see a more detailed error in your CDS. Agilent also has a tool which can help you to do diagnosis of the problem (Lab Advisor), it´s for free and can run tests on the pump / show diagnostic data.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 5 guests
