tuning question - mass gain vs AMU gain
Can anyone tell me what is the difference between mass gain and mass offset versus AMU gain and AMU offset?
----suffers separation anxiety----
Amu gain and offset are parameters that affect the mass peak width, while mass gain and offset are parameters that affect the mass axis calibration.
I believe the Gain changes the high mass faster than the low mass and the Offset changes them at equal amounts. Of course I could have that backwards but that is the difference between gain and offset.
Thanks for the replies.
I understand the difference between gain and offset - as James stated, on the Mathieu stability diagram, gain increases the slope of the scan line and offset increases the y-axis intercept.
I see how this affects peak width and resolution, but I'm not sure what the mass axis calibration is all about
The mass axis calibration converts your experimentally measured intensity-time signal into intensity-m/z plot in order to obtain an accurate mass determination of the ions in the mass spec.
It makes an ion at 218.6m/z move to 219.0 m/z to correct the mass assignment.
Thanks James and Jerole - I think I get it now
So increasing the gain of the mass axis calibration will 'stretch' the m/z axis to fit the time axis optimally, and offset will shunt it along.
