flow meter
Hi all
We would like to procure a flow meter which can be installed online in our HPLC system....
would like to get some suggestions ...
best wishes
HPLC System: HPG system with two(2) Knauer S1000 pumps- Dyamic Mixing Chamber-Knauer s3900 auto sampler-S2300 RI detector-S2500 UV detector- Raytest radioactivity detector
tarzan
We use a couple produced by GJC Instruments(UK).Check them out they are very nice
Hi ..
can you pls post a picture of your flow meter ... ? it might give us better idea how you have integrated into the HPLC set up ...
best wishes
tarzan
thank you very much ....
tarzan
Hi tarzan, check this link https://www.nriparts.com/instrumentation/flow-meters/ . Here is from where we purchased flow meter of brand Foxboro and it's working pretty well.
Users browsing this forum: Semrush [Bot] and 1 guest
