decanesulfonic
Hi, is it possible that a specific c18 column 100x4.6 needs several hundrends of column volumes to be conditioned( no retention time drift) when m.phase has decanesulfonic acid for IP(5mM)? It took us 2 days with flow rate 2, to have stable RT. we tested 2 columns of the same brand.
Yes, it is quite possible. Going back to the archives:
http://www.lcresources.com/discus/messa ... 20010652am
just use 20 times more acid for initial saturation and you should be able to do this in an hour or so.
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
Users browsing this forum: Bing [Bot] and 2 guests
