GC peaks problem
Hello.i have problem with my agilent gc.for calibration curve i inject my calibration standards twice.first one goes normally,but second one results high than first.for example first one 0,86. Second one 5.6 .(this calibration standard same concrentration and same vial) WHATS THE PROBLEM COULD BE?
Hello
The problem is that you didn't mention what is higher - peak area or retention time...
I assume it is peak area problem. Check:
1.Sampler - syringe, plunger, washing solvents
2.Inlet - check for leak, septa, split vent line/filter
Regards
Tomasz Kubowicz
Regards
Tomasz Kubowicz
It s amount problem
The problem could be any one of dozens of things. Unless you tell us what you are analysing and the operating parameters of the instrument, you are expecting us to troubleshoot by guessing.Hello.i have problem with my agilent gc.for calibration curve i inject my calibration standards twice.first one goes normally,but second one results high than first.for example first one 0,86. Second one 5.6 .(this calibration standard same concrentration and same vial) WHATS THE PROBLEM COULD BE?
In total there are 29 users online :: 1 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 28 guests
