Exporting Chromatograms from ChemStation
17 posts Page 2 of 2
I do both GC and LC, data file registers/objects for chromatograms are the same format for both.
To see the content that will be exported, load the signal and click on the chromatogram window, then select View > Window Functions > List Content. The loaded chromatogram objects will be displayed. Click on one and select List Data.
Hello
I am interested in exporting the chromatograms from ChemStation into Excel. I am using Agilent 1100 HPLC with Chemstation version A.10.02. I've read through the forums here, and I found very interesting information regarding this specific need but it is mainly for the GC. I want to be able to re-create the entire chromatogram in excel, not just the peaks. Would you kindly help in this regard? Is there a way or a specific macro to do this?
Thanks a lot,
Users browsing this forum: Bing [Bot], Semrush [Bot] and 4 guests
