Peak area summing
Using Chemstation B, I want to add areas up for certain retention time windows in the chromatogram. I have tried Area Sum but when I do that the integration gets all messed up for portions of the chromatogram. I would prefer to use normal integration parameters. I cannot use Groups because I cannot a priori identify all the components to put them into a group. At this point I am considering an export to Excel and doing the manipulation there but if anyone has suggestions in Chemstation I am all ears.
Best regards,
AICMM
Would you be able to turn off integration on the portions of the chromatogram that you are not interested in, then just do an area percent report?
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
