Online high base
Baseline chromatography rises at the end of injection. I have a sample running 6.0 minutes a peak at RRT 2.5 and 3.2 and another 5 minutes as a square (not peak) me on the chromatogram. What could this be? Appreciate your comments. Thank you
http://i59.tinypic.com/2excab7.gif
Hello
Please paste chromatogram - instruction below:
viewtopic.php?f=1&t=2617
And also please put information about your method:
-parameters
-analyzed compounds
-sample (solvent)
It is the best way to have clear picture what your problem is :)
Regards
Tomasz Kubowicz
Without information I can only guess: you are running a gradient?
Information on the mobile phase and composition of MP would be highly appreciated.
With a detection wavelength of 205 nm it could be almost anything.
Hello
Please provide more details (I mentioned that in first post).
I suspect that you run gradient and when peak elution in 5.3min starts, gradient is changing to initial settings.
Regards
Tomasz Kubowicz
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
