Plunger seal vs. Rinse seal
We have a Shimadzu LC-10ATvp and need to replace both the plunger seal and the rinse seal. I am wonder what the difference is between these two items because they are very similar in appearance.
Different color?) Very poor pictures in manual so i'm not sure which is plunger.
But normally black one is plunger seal.
Kind regards,
Ivan Styskin
LCCO Biotech
Ivan Styskin
LCCO Biotech
Hi.
I have serviced the Shimadzu HPLC for >10 years. The plunger seal (black/yellow) and back seal (white) are almost the same. However, the back seal is not strong as the plunger seal.
Do you want to use motor oil (color code yellow) as a substitute for antifreeze (color code green)?
Note: I do not work for Shimadzu.
Alfred
Alfred
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
