Can't obtain performance check for GC-MS?
Greetings,
For my GC/MS (7890A/5975A), I've got an ideal PCI autotune report for my instrument. Even-though I can't fulfill the performance check using the Benzophenone standard. i.e. when injecting 1ML of the standard the chromatogram shows noise and more than one peak & the ms spectrum doesn't recognize the benzophenone?
Any help will be appreciated.
Greetings,
Is 1 milliliter correct or is that supposed to be 1 microliter injection?
Thanks James for the response
The injected volume is 1 Micro-liter
Hello
Please provide more information:
-please paste autotune report
-please paste chromatogram you have problem with
Otherwise is more guessing than real help.
Regards
Tomasz Kubowicz
Dear Tomasz,
I couldn't find how to attached the files here..
So would you provide an email where I can send all the related files..
Mine is khalid.janabi@gmail.com
Thanx,
Dr. Khalid
Hello
Please check link below:
viewtopic.php?f=2&t=12659
Good luck
Regards
Tomasz Kubowicz
Thank you Tomasz.. it was very helpful
I've upload them to my dropbox..
Kindly follow the link..
https://www.dropbox.com/sh/vlvtye0fdng0 ... XbTAa?dl=0
All the best,
