Peak Clipping
Hello all. I've got a Clarus 500 with on-column injection using TotalChrom 6.3.1. I've recently doubled the injection volume for a method I'm running. However, an internal standard peak is getting clipped. I've tried changing the Full Scale value under Scaling Parameters to 2000, but this made no difference. The topscale for the analysis is set at 1000. Any help with this issue would be greatly appreciated!
Didn't you overload your detector ?
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot] and 26 guests
