Rolling, rolling, rolling
Having trouble figuring out the cause of my rolling baseline. The roller is very symmetrical and has a peak to valley time of approx. 10 minutes. Won't bore you w/ the details of my trouble shooting. Any thoughts?
s
When the time between two injections correlates with the baseline rolling time you see a (very) late eluating peak.
the rolling baseline occurs during equilibration as well as during runs.
How about temperature fluctuations? Air conditioning going off and on? Column heater off/on?
If the problem is caused by a late eluating peak, you get rid off the problem by flushing the column with high % to 100% organic solvent.
The next equilibrating with your normal mobile phase should show a smooth baseline.
Using a solvent with 10 to 20% less water show such a compound coming from the sample(s) within normal run time.
In total there are 26 users online :: 3 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot], Trishia and 23 guests
