chromeleon 7 how to export AIA(cdf)
chromeleon 6.8 could export aia,but chrome 7 could not. who konws some way, thank you
Hi hqs_hua
Sorry to correct you, but in the actual CM Version (7.2) it is possible to export data as *.cdf (AnDI/NETcdf, formerly known as AIA), and other formates like pdf, xls, gaml and txt. Simply right click the sequence and select export.
If you are using an older Chromeleon Version (e.g. 7.1) contact your friendly Thermo/Dionex Sales Represenative. Hi will be happy to assist you.
Cheers,
Cheers,
Stefan Brand
Thermo Fisher Scientific
We are converting files to AIA cdf for our lims system. The new system of chromeleon does not have the Operator. Please the is urgent.
Hi
What do you mean with "does not have the operator"?
Chromeleon 7 can easy export sequences / samples to cdf files (and other formates as well). The procedure is the same as already described above. All information can be found in the help file, all export types are described in detail or call your friendly Dionex/Thermo representative for assistance.
Best regards
Best regards
Stefan Brand
