Sulphamic acid on LCMS..
Hi everybody,
We have to transfer a method from LC-UV to LCMS (ESI). In the original method there is sulphamic acid and NaOH in the mobile phase (pH2) and a silica column, C18.
My question is about the use of sulphamic acid and NaOH with the detector MS.. I think we need to change them with TFA to get the same pH and similar elution.
What do you think about this?
Thanks in advance for the help,
Have a good day!,
Davide
The TFA could suppress the response. Could try 10 mmolar ammonium formate adjusted to pH 3.5 with formic acid and see if you get adequate retention with a high aqueous content of the mobile phase.
Sailor
In total there are 34 users online :: 0 registered, 0 hidden and 34 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 34 guests
