Where to purchase a solid sampler?
Hi Joe
Re centrifugation.
Since you are getting a clear layer after centifugation I would still argue that it is just a question of time under the conditions that you are using. Gravity always wins
There have been some interesting studies carried out by many students proving the correlation between the increasing effect of gravity versus the number of pints consumed
I hope that you have enough clear sample to work with.
Kind regards
Ralph
Re centrifugation.
Kind regards
Ralph
Regards
Ralph
Ralph
Eh, it was a thought. Putting them in the freezer will most likely be loads cheaper. But good to know you can use liquid nitrogen if you need to extract them right now.
But, I guess that would mean that the mites are not vomiting.
Hi Joe
green colouration
Your green colouration is likely to be from the leaf component colours after ingestion by the mite
The colours of some of the bands on your TLC plate in an earlier post are consistent with those expected from a leaf extract, separating the green colour into xanthophylls carotene and chlorophyll
From my studies, they are also consistent
I will try to find that study
Regards
Ralph
green colouration
Regards
Ralph
Regards
Ralph
Ralph
