Looking for 2 channel HPLC data sytem
I am looking for a simple low-cost two-channel data system for HPLC (Waters 484 and 486 DAD detectors and other Waters detectors of same era). I don't mind purchasing used equipment. I have plenty of PCs that could be used (Windows or Linux). Initially, just need something to show I have peaks. Methods I will be using were developed using a SP 4200 recording integrator.
Thank you,
John
On e-bay , search '' baseline '' software , chinese origin , around $250
Im using Baseline (China) which I purchased off eBay. Its a two channel system and works with a number of detectors, but pretty sure it wont work with data intensive detectors such as a DAD/Photodiode. The system is meant for simple detectors that have analog outputs (UV, conductivity, etc).
What system are you using it with? We have our connected to a LC-10 with SPD-10A (UV) detector.
