USP Chlorpheniramine Maleate Extended-Release Tablets RS
Pl clarify whether it is a phamacoepial requirement to calibrate the Dissolution appartus with USP Chlorpheniramine Maleate Extended-Release Tablets RS or not ?
if i am testing any Deleayed/Extended release tablets then calibrating the Apparatus with USP Chlorpheniramine Maleate Extended-Release Tablets RS is mandatory?
There is appropriate forum for dissolution:
http://www.dissolution.com/vbulletin/fo ... ay.php?f=1
You may ask your question to this site. :wink:
As far as I know USP chlorpheniramine maleate extended release tablets are used for apparatus 3 (reciprocating cylinder). See: USP General Chapters: <724> DRUG RELEASE - EXTENDED-RELEASE ARTICLES-GENERAL DRUG RELEASE STANDARD
It depends on which apparatus you're using.
We commonly use 1 & 2 - I don't think we do any CPM testing when we calibrate and we do run MR tablets, capsules & suspensions on them.
DR
Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
