Solvent grade definitions
hello
I am writing up my project and i have just written the term "HPLC grade water". I made HPLC grade water by passing water through a filter !! Is this the definition of a HPLC grade solvent ie one that is passed through a filter or is there a more official definition ?? Im also wondering what the terms analytical grade and reagent grade mean as well . Can anyone help with "official " definitions ? :?:
These commercial terms may not have an official definition (I may be wrong)
HPLC grade water is water suitable for use in HPLC. See a vendor who sells HPLC grade water and see the specifications listed. It is water that has been filtered but also contains a minumum of non-aqueous material (living organisms, minerals, etc) and there may be a dissolved gas specification as well.
Analytical grade simply means it is high purity, suitable for chemical use as a reagent or starting material in a process or reaction.
Reagent grade also means a highly purified version of the chemical.
The USP and the ACS may have offical definitions. Look up their web sites and see what you can find.
best wishes,
Users browsing this forum: Semrush [Bot] and 1 guest
