GC-ECD Baseline Noise Help
Page 2 of 2
Please post your detector and injector temperature. What are the flows? The ferrules used on the detector side are different than the injector side. The micro ECD is very sensitive. You should always use gas traps. Also, have you leak checked the system to make sure you have no leak?
Page 2 of 2
