Method for analysis of MTBE by GC-FID?
I am struggling to find a good method for MTBE using a GC-FID, i am having problems getting peaks at low concentrations (low ppb range). If anyone has anysuggestions it would be greatly appreciated.
Purge and trap with heated sparging should reach that level easily.
SPME will perform the analysis levels you require. Also if your automated HS and matrix are suitable low ppb levels of MtBE are possible with that technique as well.
the question is what is Your low level? The best way to separate MTBE from hydrocarbons is the LOWOX-column from CP. 100ppb is a lower limit. Handling is a special. If You have questions ask me.
rgs
Bernd Mischke
bm
Users browsing this forum: Ahrefs [Bot] and 4 guests
