IP344
Hi Everyone,
If someone can help to calculate the ration of valley to peak height as per IP344.
Hi Muhammad
Some more information and clarification on the ratio that you require and the analysis would be helpful.
I don't have method IP344 available - nor will most others - I presume that the IP refers to the Institute of Petroleum?
You could just cut and paste the relevant section on the ratio required
Kind regards
Ralph
Regards
Ralph
Users browsing this forum: Bing [Bot] and 14 guests
