TCD fuse 1.0A use, if using for 1.6A fuse, that it is fine?
Gas chromatography detector, TCD recomend use for 1.0A fuse, but i for useing 1.6A fuse do not it is fine?
Fuses are cheap. I would only risk using a higher amperage fuse as a temporary measure until I could get the correct one.
thanks for answer.
so high amperage fuse danger(instrument damage or risk).
ok i got it, thank you for teacher
In total there are 20 users online :: 1 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 19 guests
