Varian Prostar 335 error
Page 2 of 2
I recently built a Varian 335 HPLC system running MSWS 6.41 workstation. I also have a 325 detector. I understand I need a program called Polyverify to perform higher level maintenance tasks on the 335. I was wondering where this program could be found and if it will also work on the 325 (or does the 325 require not poly just Verify)? Many thanks in advance!
I can get you a copy of the PolyVerify software if you want. Give me your email address or dropbox and I can send it to you in a couple days.
Also, you might want to try and re-calibrate the lamps to fix the CC Slit line peak error.
Hello-
I was wondering if you still had a copy of PolyVerify? I have a 335 I would like to keep running.
Thanks!
Page 2 of 2
In total there are 23 users online :: 2 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 21 guests
