Derivatization procedure
Hi All,
I want to analysis of a mixture of compounds by GC/MS. One of the compounds contains Proline moiety and the other contains secondary and primary amine functional groups.
My guestion is
Which derivatization procedure should I use ? Can I use silylation for derivatization of compounds?
Thank you for your advice.
:roll:
I have found that the t-butyldimethylsilyl derivatisation (after Woo and Chang - Journal of Chromatography, 638 (1993) 97-107) works well for proline. I use MTBSTFA+1%TBDMCS reagent in the presence of pyridine heated to 70°C for 2hrs. Hope that helps,
Ralph
Hello Ralph
This information is usefull for me. I will try to this procedure.
Thank you for your help
:D
Users browsing this forum: Google [Bot] and 4 guests
