Empower3 - Pass / Fail R^2 - Custom field
Hi all,
I'm trying to create a boolean custom field in Empower for an R^2 >= x
I've tried:
GTE((R^2),0.998)
However, R^2 is a result, and for a result custom field I get "A peak/component field cannot be used without SUM, MIN, MAX or AVE when creating a Result type custom field.
All results refer to one calibration curve.
How can this be done?
Simple :
Create a CF type peak that refer to R^2
Use your new CF in your formula
For some reason the R2 is different per standard injection.
I've added a calibrate line at the end of the sample set, but this makes no difference.
hi
try this as a guide , though not sure why R2 is different for each standard
Calibration type total maybe:
https://www.waters.com/webassets/cms/li ... riksen.pdf
Hi
Modify the field type to PEAK! It will work.
In total there are 29 users online :: 0 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 29 guests
