Fronting peaks with PFPP column
19 posts Page 2 of 2
Bruce,
Thank you for your information.
Excel
Hi Members,
What would you do if inpurity peaks starting to merge with the main peak? (the initial resolution between imputiry and main peak is about 1.5) column: Waters xterrra C8, mobile phase H2O and ACN, gradient 90% water to 10% water after 40 minutes. The main compound is testosterone palmitate and the impurity is a little tiny unknown peak. I noticed the same behavior in two "new" Waters C8 columns (about a month old). I had no choice but to buy another two columns :cry: to complete the validation work.
Thanks in advance,
ntruong
Hi Members,
What would you do if impurity peaks starting to merge with the main peak? (the initial resolution between impurity and main peak is about 1.5) column: Waters xterrra C8, mobile phase H2O and ACN, gradient 90% water to 10% water after 40 minutes. The main compound is testosterone palmitate and the impurity is a little tiny unknown peak. I noticed the same behavior in two "new" Waters C8 columns (about a month old). I had no choice but to buy another two columns :cry: to complete the validation work.
Thanks in advance,
ntruong
Hi Mav,
Opps! I don't mean to steal :twisted: your post. I will "void" mine :oops:
Best regards,
ntruong
