Problem with Waters Empowers 2 FS3/Waters UV detector 2487
Hello everybody! First time poster so please let me apologize if this is not the right place to post. Feel free to move the post where it fits most.
Anyway, I`m a post-doc in a research lab, and I have been using Waters systems since I started purifying proteins. Just to say that my experience is hands-on based mostly. Anyway I just bought a used system made up of 600 quad pumps, 600 controller, 717 autosampler and the dual UV detector 2487.
I connected everything with IEEE-48 cables and to the computer with the LAC/E board. Everything seems to work just fine, in the sense that I see under waters system/nodes all the component of my system and they are all OK, and I can "control" the UV detector, in the sense that I can write a method setting whichever wavelength I want and the detector will do change the wavelength to the one I set. However, my confusion/question is that I also have a second system (in a different lab) in which I have a WAters 2489 detector. When I open empowers in this second system I can actually see on screen the OD reading of the detector, and I have the ability to turn off the lamp from there, the screen, without having to write it in the method.
The 2489 is not connected with IEEE-488 cable, but with an ethernet cable to a SAT/IN module (I think that is the name). So my question is, am I connecting the 2487 in a wrong way, or that function (to have on screen the OD and lamp on/off) is unique of the 2489!
Thank you all for reading this!
IEEE detector lamps can't be turned off in the same way ethernet detector lamps can be. All is working correctly.
DR
